Drawing format: Passing relations for Part or Assembly
_ML_
Goal: One drawing format which will populate specific data and not matter if the drawing model is a single part or an assembly.
Using a repeat region I am trying to pass model material along with a few other items into a title block.  I can successfully make this happen by
  1. Using 2 different formats so the repeat region calls out
    1. mbr/ptc_material/ptc_material_name
    2. asm/mbr/ptc_material/ptc_material_name
  2. Using 1 format, but making all drawing models assemblies so that the item 2 always is present.
Is there a way to use repeat region relations in order to have a single format with a repeat region which works if the drawing model is a part or an assembly?  I'm not sure if it is even possible, or if I simply am having an issue with syntax and formatting.
BenLoosli
(To:_ML_)
Try using
IF asm.mbr.type == 'prt'
use part parameters
endif
if asm.mbr.typ == 'asm'
use assembly parameters
endif
_ML_
(To:BenLoosli)
Sadly, no such luck.
The following relations will verify in the drawing of an assembly but does not work on drawing repeat region.  The same relations in a drawing of a part will not verify and result in errors.
if asm_mbr_type == 'PART'
test = mbr_ptc_material_ptc_material_name
endif
if asm_mbr_type == 'ASSEMBLY'
test = asm_mbr_ptc_material_ptc_material_name
endif
RPN
(To:BenLoosli)
Explain the difference between part and assembly parameter😵
Do you have different formats for this 2 solid types? 😵
