Flexible component done by Java Toolkit
Gucio
Hi folks,
Please look at simple assembly flex_top_asm.asm. It contains one component flex_part2.prt.
In part thre are defined:
a) 3 dimensions as flexible (open file in new window, then File >  Prepare > Model Properties > Flexible > Dimensions);
b) 3 parameters as flexible (open file in new window, then File >  Prepare > Model Properties > Flexible > Parameters);
Based on PTC sample I've modified method, that should be started on asm level. As a result, component flex_part2.prt will be changed into flexible one, and in Varied Items table dimensions will be shown.
Question is:
How to do it with parameters. How to add them to Varied Items table??
Sample code:.
public static void makeFlexibleComponent(int componentID) {
ComponentFeat CFeat = null;
WComponentFeat WCFeat = null;
try {
FileWriter file = new FileWriter("AssemblyItemExample.txt");
BufferedWriter fp_out_asmitem = new BufferedWriter(file);
fp_out_asmitem.write("- gucioFlexibleComponent -");
fp_out_asmitem.newLine();
fp_out_asmitem.write("==============================");
Session session = pfcSession.GetCurrentSession();
/* Open top assembly FLEX_TOP_ASM.asm in Creo Session */
Model CurrModel = session.GetCurrentModel();
Assembly PAsm = (Assembly) (CurrModel);
WAssembly WAsm = (WAssembly) (CurrModel);
Features Feats = PAsm.ListFeaturesByType(Boolean.FALSE, FeatureType.FEATTYPE_COMPONENT);
Model ItemOwner = null;
for (int i = 0; i < Feats.getarraysize(); i++) {
if (Feats.get(i).GetId() == componentID) {
fp_out_asmitem.write("For Feature ID: " + Feats.get(i).GetId());
fp_out_asmitem.write("With Feature Number: " + Feats.get(i).GetNumber());
CFeat = (ComponentFeat) (Feats.get(i));
WCFeat = (WComponentFeat) (CFeat);
intseq seq = intseq.create();
seq.set(seq.getarraysize(), componentID);
String ItemOwnerName = ((ComponentFeat) Feats.get(i)).GetModelDescr().GetFileName();
ItemOwner = session.GetModelFromFileName(ItemOwnerName);
boolean is_flex = WCFeat.IsFlexible();
fp_out_asmitem.write(" Is Component Already Flexible ? : " + (is_flex ? "YES" : "NO"));
intseq dim_id_array = intseq.create();
dim_id_array.set(0, 8);
dim_id_array.set(1, 4);
dim_id_array.set(2, 5);
AssemblyItems AsmItemArray = AssemblyItems.create();
for (int i = 0; i < dim_id_array.getarraysize(); i++) {
fp_out_asmitem.write("ABC " + dim_id_array.get(i));
AssemblyItemInstructions ThisAsmInstr = wfcComponentFeat.AssemblyItemInstructions_Create(ItemOwner,
ModelItemType.ITEM_DIMENSION, dim_id_array.get(i));
AssemblyItem ThisAsmItem = WAsm.CreateAssemblyItem(ThisAsmInstr);
AsmItemArray.append(ThisAsmItem);
fp_out_asmitem.write("before");
WCFeat.SetAsFlexible(AsmItemArray);
Dimension dim1 = ((Dimension) WCFeat.ListVariedItems().get(0));
Dimension dim2 = ((Dimension) WCFeat.ListVariedItems().get(1));
Dimension dim3 = ((Dimension) WCFeat.ListVariedItems().get(2));
dim1.SetDimValue(111);
dim2.SetDimValue(222);
dim3.SetDimValue(333);
fp_out_asmitem.write("after");
fp_out_asmitem.write("-gucioFlexibleComponent-");
fp_out_asmitem.close();
return;
} catch (Exception e) {
System.out.println(e + " " + e.getMessage());
Krzysztof
YaroslavSin
(To:Gucio)
Create instruction AssemblyItemInstructions_Create.
As a type use ModelItemType._ModelItemType_null.
For Parameter you need specify a name AssemblyItemInstructions.SetItemName. Maybe in AssemblyItemInstructions_Create for ItemId you can pass 0 (zero) in case of a parameters.
6 REPLIES 6
YaroslavSin
(To:Gucio)
hi  ysinitsyn,
could you look at it?? There is still  issue 😞
Krzysztof
YaroslavSin
(To:Gucio)
Not sure what this mean.
From the documentation
The value of this argument is ignored for
parameter. For parameter, pass this value as _ModelItemType_null.
static final int _ModelItemType_null - Enum null value.
 Try to use
null
as the argument.
I've tried earlier - no success.
What is more, I used log to get an error message
Result:
Krzysztof
YaroslavSin
(To:Gucio)
Try to create AssemblyItemInstructions_Create with any ModelItemType.
Then set a name AssemblyItemInstructions.SetItemName.
Maybe, the item type will be ignored in case of a parameters (as described in the documentation).
For me, looks like a bug in Java API. ModelItemType class don't have _ModelItemType_null. Only null
package com.ptc.pfc.pfcModelItem;
import com.ptc.cipjava.jxenum;
public final class ModelItemType implements jxenum {
  private int __Value;
  public static final int _ITEM_FEATURE = 0;
  public int getValue() { return this.__Value; }
  public static ModelItemType FromInt(int paramInt) {
    switch (paramInt) {
      case 0:
        return ITEM_FEATURE;
      case 1:
        return ITEM_SURFACE;
      case 2:
        return ITEM_EDGE;
      case 3:
        return ITEM_COORD_SYS;
      case 4:
        return ITEM_AXIS;
      case 5:
        return ITEM_POINT;
      case 6:
        return ITEM_QUILT;
      case 7:
        return ITEM_CURVE;
      case 8:
        return ITEM_LAYER;
      case 9:
        return ITEM_NOTE;
      case 10:
        return ITEM_DIMENSION;
      case 11:
        return ITEM_REF_DIMENSION;
      case 12:
        return ITEM_SIMPREP;
      case 13:
        return ITEM_SOLID_GEOMETRY;
      case 14:
        return ITEM_TABLE;
      case 15:
        return ITEM_DTL_ENTITY;
      case 16:
        return ITEM_DTL_NOTE;
      case 17:
        return ITEM_DTL_GROUP;
      case 18:
        return ITEM_DTL_SYM_DEFINITION;
      case 19:
        return ITEM_DTL_SYM_INSTANCE;
      case 20:
        return ITEM_DTL_OLE_OBJECT;
      case 21:
        return ITEM_EXPLODED_STATE;
      case 22:
        return ITEM_EDGE_START;
      case 23:
        return ITEM_LOG_EDGE;
      case 24:
        return ITEM_EDGE_END;
      case 25:
        return ITEM_XSEC;
      case 26:
        return ITEM_LAYER_STATE;
      case 27:
        return ITEM_COMBINED_STATE;
      case 28:
        return ITEM_STYLE_STATE;
      case 29:
        return ITEM_RP_MATERIAL;
      case 30:
        return ITEM_VIEW;
      case 31:
        return ITEM_SURF_FIN;
      case 32:
        return ITEM_ANNOT_PLANE;
      case 33:
        return ITEM_ANNOTATION_ELEM;
      case 34:
        return ITEM_SET_DATUM_TAG;
      case 35:
        return ITEM_GTOL;
      case 36:
        return ITEM_BODY;
      case 37:
        return null;
    return null;
  public static ModelItemType FromInt(Integer paramInteger) {
    if (paramInteger == null) {
      return null;
    return FromInt(paramInteger.intValue());
  private ModelItemType(int paramInt) { this.__Value = paramInt; }
  public static int getValue(ModelItemType paramModelItemType) {
    if (paramModelItemType == null) {
      return 37;
    return paramModelItemType.getValue();
  public static final ModelItemType ITEM_FEATURE = new ModelItemType(false);
  public static final int _ITEM_SURFACE = 1;
  public static final ModelItemType ITEM_SURFACE = new ModelItemType(true);
  public static final int _ITEM_EDGE = 2;
  public static final ModelItemType ITEM_EDGE = new ModelItemType(2);
  public static final int _ITEM_COORD_SYS = 3;
  public static final ModelItemType ITEM_COORD_SYS = new ModelItemType(3);
  public static final int _ITEM_AXIS = 4;
  public static final ModelItemType ITEM_AXIS = new ModelItemType(4);
  public static final int _ITEM_POINT = 5;
  public static final ModelItemType ITEM_POINT = new ModelItemType(5);
  public static final int _ITEM_QUILT = 6;
  public static final ModelItemType ITEM_QUILT = new ModelItemType(6);
  public static final int _ITEM_CURVE = 7;
  public static final ModelItemType ITEM_CURVE = new ModelItemType(7);
  public static final int _ITEM_LAYER = 8;
  public static final ModelItemType ITEM_LAYER = new ModelItemType(8);
  public static final int _ITEM_NOTE = 9;
  public static final ModelItemType ITEM_NOTE = new ModelItemType(9);
  public static final int _ITEM_DIMENSION = 10;
  public static final ModelItemType ITEM_DIMENSION = new ModelItemType(10);
  public static final int _ITEM_REF_DIMENSION = 11;
  public static final ModelItemType ITEM_REF_DIMENSION = new ModelItemType(11);
  public static final int _ITEM_SIMPREP = 12;
  public static final ModelItemType ITEM_SIMPREP = new ModelItemType(12);
  public static final int _ITEM_SOLID_GEOMETRY = 13;
  public static final ModelItemType ITEM_SOLID_GEOMETRY = new ModelItemType(13);
  public static final int _ITEM_TABLE = 14;
  public static final ModelItemType ITEM_TABLE = new ModelItemType(14);
  public static final int _ITEM_DTL_ENTITY = 15;
  public static final ModelItemType ITEM_DTL_ENTITY = new ModelItemType(15);
  public static final int _ITEM_DTL_NOTE = 16;
  public static final ModelItemType ITEM_DTL_NOTE = new ModelItemType(16);
  public static final int _ITEM_DTL_GROUP = 17;
  public static final ModelItemType ITEM_DTL_GROUP = new ModelItemType(17);
  public static final int _ITEM_DTL_SYM_DEFINITION = 18;
  public static final ModelItemType ITEM_DTL_SYM_DEFINITION = new ModelItemType(18);
  public static final int _ITEM_DTL_SYM_INSTANCE = 19;
  public static final ModelItemType ITEM_DTL_SYM_INSTANCE = new ModelItemType(19);
  public static final int _ITEM_DTL_OLE_OBJECT = 20;
  public static final ModelItemType ITEM_DTL_OLE_OBJECT = new ModelItemType(20);
  public static final int _ITEM_EXPLODED_STATE = 21;
  public static final ModelItemType ITEM_EXPLODED_STATE = new ModelItemType(21);
  public static final int _ITEM_EDGE_START = 22;
  public static final ModelItemType ITEM_EDGE_START = new ModelItemType(22);
  public static final int _ITEM_LOG_EDGE = 23;
  public static final ModelItemType ITEM_LOG_EDGE = new ModelItemType(23);
  public static final int _ITEM_EDGE_END = 24;
  public static final ModelItemType ITEM_EDGE_END = new ModelItemType(24);
  public static final int _ITEM_XSEC = 25;
  public static final ModelItemType ITEM_XSEC = new ModelItemType(25);
  public static final int _ITEM_LAYER_STATE = 26;
  public static final ModelItemType ITEM_LAYER_STATE = new ModelItemType(26);
  public static final int _ITEM_COMBINED_STATE = 27;
  public static final ModelItemType ITEM_COMBINED_STATE = new ModelItemType(27);
  public static final int _ITEM_STYLE_STATE = 28;
  public static final ModelItemType ITEM_STYLE_STATE = new ModelItemType(28);
  public static final int _ITEM_RP_MATERIAL = 29;
  public static final ModelItemType ITEM_RP_MATERIAL = new ModelItemType(29);
  public static final int _ITEM_VIEW = 30;
  public static final ModelItemType ITEM_VIEW = new ModelItemType(30);
  public static final int _ITEM_SURF_FIN = 31;
  public static final ModelItemType ITEM_SURF_FIN = new ModelItemType(31);
  public static final int _ITEM_ANNOT_PLANE = 32;
  public static final ModelItemType ITEM_ANNOT_PLANE = new ModelItemType(32);
  public static final int _ITEM_ANNOTATION_ELEM = 33;
  public static final ModelItemType ITEM_ANNOTATION_ELEM = new ModelItemType(33);
  public static final int _ITEM_SET_DATUM_TAG = 34;
  public static final ModelItemType ITEM_SET_DATUM_TAG = new ModelItemType(34);
  public static final int _ITEM_GTOL = 35;
  public static final ModelItemType ITEM_GTOL = new ModelItemType(35);
  public static final int _ITEM_BODY = 36;
  public static final ModelItemType ITEM_BODY = new ModelItemType(36);
  public static final int __Last = 37;
But in AssemblyItemInstructions_Create I see a check that the arguments must not be equal null.
public static AssemblyItemInstructions AssemblyItemInstructions_Create(Model paramModel, ModelItemType paramModelItemType, int paramInt) throws jxthrowable {
    if (paramModel == null) {
      throw XNullInNonOptArg.Create("ItemOwner");
      throw XNullInNonOptArg.Create("ItemType");
    CIPRemoteComm cIPRemoteComm = CIPRemoteApp.getComm();
    CIPTransport cIPTransport = CIPRemoteApp.getTransport();
    long l = cIPTransport.obtainObjectPtr(paramModel);
    cIPRemoteComm.sendCall();
    cIPTransport.sendInt(6021);
    cIPTransport.sendObjectPtr(l);
    cIPTransport.sendInt(ModelItemType.getValue(paramModelItemType));
    cIPTransport.sendInt(paramInt);
    cIPRemoteComm.processMessages();
    return (AssemblyItemInstructions)cIPTransport.recvObject(CIPRemoteApp.getObjectMaker());
hi @YaroslavSin ,
just in case you are still interested in my case, PTC has opened SPR.
Krzysztof
