Hello all,
I have a situation where I want to save table in CSV format.
I am using 'ProDwgtableSave' API for the same.
ProError ProDwgtableSave(ProDwgtable* table, ProPath path, ProDwgtableFormattype table_format, int segment_id );
The API extern 'ProDwgtableSave' requires 'segment id' as an argument.
I am using 'ProDwgtableSegCount' API to get segment count.
ProError ProDwgtableSegCount (ProDwgtable *p_table,
int *n_segs);
But I am not finding a way to get 'segment id' from the number of segments.
Therefore I am not able to save CSV file as it is not getting specific table data.
Though I am able to save TXT file as it does not require 'segment id' as argument.
Thanks in advance.
Pratik Chougule
Hi Pratik
int segments;
if (ProDwgtableSegCount(table, &segments) == PRO_TK_NO_ERROR) {
if (ProDwgtableSegSheetGet(table, 0, &segsheet) != PRO_TK_NO_ERROR) {
ProDwgtableSegSheetGet(table, -1, &segsheet);
segments = -1;
else {
segments = 0;
If you have a multisegment table 0 is the first segment. If you have a single segment table -1 could also be the segment. So sometimes you need the 0 sometimes the -1. Just make a encapsulated call and try both.
Br,
Eike
Maybe it is ordinal number of a segment?
If you have several segments in table, then try to put 0, 1, ... in function as segment id
Hi Pratik
int segments;
segments = -1;
else {
segments = 0;
Br,
Eike
Yes, Eike Hauptmann, it worked with 0 value.
Pratik
It is not sometimesヤ 😁
p_table - The table in question.
segment - The segment ID you want to check (or -1 for a one seg. table).
You have the count !
tk_status = ProDwgtableSegSheetGet( (ProModelitem*) &p_table,segment,&segsheet);
Thanks Alexandrite, it worked with 0 value.
Pratik
