I am using Creo 10. I have a number of udfs meant for Hydraulic Manifold Block design ease. It is all independant udfs. I had started developing them from about 2005. It includes BSP/NPT ports, angle holes, holes within holes, cartridge cavities etc. It comes out with its own 3D note which can be pulled into the 2D drawings, thus ensuring data transmissibility. Hole tables are also creatable, with hole coordinates in each plane being measured from the centre of the block. But this can be changed, if one so desires.
If anyone is interested in using them, please ping me.
A note to the moderator:
I am a retired Hydraulic designer (32 years). These tools come with that rich experience built into them. I am not demanding money or anything in return. I just want to see the tools prosper in all environs
Saju
Best Regards
Hi @Sp_7827276
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best regards,
Best Regards
Dear Moderator
I would like to emphasise that I am willing to share my work, if anyone is interested. It does not stop with one tool. I have a number of tools. One of the most used samples, is what I have shared above, namely the BSP or NPT port, as used by manifold manufacturers world wide. They differ from normal holes in that the hole depth is always mentioned to the tip, because, when we are working with hydraulic manifold blocks, we have to be very careful about wall punctures, between adjacent holes. Similarily, the port once put on a surface, should not inadvertently move outside the surface, when we move the port during design adjustments. The hole notes should be accurately displaying the details of the port, irrespective of whether, it has a spot-face (counter bore) or not
Apart from these ports, there are cartridge valves of varying configurations with connecting holes at varying depth, Cetop valves, slip-in-cartridges etc.
Saju
