Hi everyone,
I'm trying to run a simple Java application. I have jdk 17. I checked Creo Object Toolkit Java in the installation. I'm struggling to find what to put into my classpath/ if I need one at all. The requred .jar files I've seen mentioned online don't seem to be in my install, but those pertained to older versions. Any tips would help!
Adam
by chance can you confirm you already went through that article : https://www.ptc.com/en/support/article/CS245175 ?
Hello @AA_13175218,
It looks like you have a response from a support expert. If it helps you solve your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
