is possible launch creo parametric at a specific location on the screen?
I use windows_scale 0.5 and the window moves to the top left.
I would like to open more at the top right, down left & down right.
I did it.
To activate the last session icon I have to open at least one file or create a new one, save it and close the CAD.
Next time I start CAD I can recover the last session.
Grazie
C_Spagnolli,
Not specific to PTC, but many desktop managers can do this. NVIDIA has nView Desktop Manager for example.
Dan N.
Restore last session, may do that for you as far I know, but from start you have probably to code.
I tried but I can't.....
I use many files config.pro and file_start.ink
How do I save last sessions for use?
Check that you have the config.pro option last_session_retrieval set to Yes
There is also an option where this is stored, for this check "last_session_directory_path"
Yes I did it and it created the folder in the directory_path, but then I can't start the last session.
Do you have an example?
You need to pick this,
Optional you can start with a trail file, and add
~ Sync PERM_CHECKER_DLG
~ Command `ProCmdOpenLastSession`
This will retrieve the models as well, how to avoid this, I don't know.
I would run a mapkey in the trail file, this is more save!
And after load erase all models 🙂
What am I doing wrong?
Start file ink.
DIRECTORY C:\PTC with folder pseinfo created by last_session_directory_path
Open cad but the last session it's off
Start file ink.
I guess your config.pro contains following option
LAST_SESSION_RETRIEVAL no
No it doesn't contain it.
I tried adding LAST_SESSION_RETRIEVAL yes but it doesn't change anything.
did you check all config.pro files loaded during Creo startup? In which directories did you search for config.pro?
If you use config.sup then you have to check its contents, too.
I did it.
Grazie
Hi.
I tested Creo 9.0.2.0:
When I started next session, window size & position was restored.
