Has anybody found a solution for changing the output order of the tools in the manufacturing model? I want to control the order by tool, simply by grouping togethersequences that use the same tool. We do this manually via the menu manager by navigating:
Machining > Output Order > Define > By Rule > By Tool > Done
and then clicking on the top tool until all the tools have been selected.
This can be done with a macro, but the tools will be different for each part that is programmed, and the specific tool name ("T0020") is required for the macro, meaning there will be some that are not selected and in many cases, selected in the wrong order.
Any help would be greatly appreciated.
Thanks for your time,
Corey
