Mapping Pan behavior to Mouse buttons only
RW_12885897
3-Newcomer
As a disabled user with only one hand, I need a way to setup Creo Parametric to only use Mouse buttons for PAN. This is the only function that I cannot seem to find a work around from Shift + RMB to PAN in my model. Yes, I can use the Pan icon and have been doing that, but it is extra clicks and impacts productivity.
Other CREO PTC applciations have the ability to modify and control the Pan/Zoom/Rotate features (Creo View, Creo Elements etc), Creo Parametric does not have this ability for those of us that need accomidations due to physical disability and limitations.
When will this be fixed for the user community?
remy
(To:RW_12885897)
Hi
It's not perfect but you can have the Pan tool readily available to your RMB you can customize it.
  1. Open a model and RMB (long) in the graphics window: remy_0-1749214413094.png
  2. Select Customize
  3. Type "Pan"
  4. Drag it to the menu on the left and add it in the cascade :remy_1-1749214491454.png
To use it :
  1. RMB button on the graphics windows
  2. then select Pan
  3. When you're done MMB to leave the tool
That's setting is then managed with *.ui file.
If you have not already you can go through that article to manage it : https://www.ptc.com/en/support/article/CS288341
RW_12885897
3-Newcomer
(To:remy)
Remy, Thank you for the methodology, however, that is still more clicks and actions I desire to take since I use Pan constantly during my activities within CREO Parametric. I would prefer to see consistency between PTC products and an improvement to the existing behavior and configuration abilities.
Dear @RW_12885897,
We sincerely appreciate your feedback, as it is essential for improving our products. If you have any suggestions, feature requests, or ideas for enhancing Creo Parametric, please feel free to share them on the Creo Parametric Ideas board, if you haven't done so already.
Why should you post your idea?
  • Your insights will be directly accessible to our product management and development teams.
  • Other users can vote and comment, which can strengthen your idea.
  • Top ideas may be considered for future releases.
To begin, please visit the Creo Parametric Ideas board and submit your idea.
For more on product ideas, you may watch this video.
Thanks & Best Regards,
Vivek N
Community Moderation Team.
Hello @RW_12885897
You have a response from a support expert. If it helped to answer your question, please mark the reply as the Accepted Solution.
Vivek N.
