I am developping a bit with Pro/Toolkit. First I did my application as spawn mode (exe) as they advice us. I have no problem with that, I compile it and register it and then it works fine in ProE 64 bits. Then I decided to do the same application but as DLL mode in order to have my application running faster but I can't get it to work :
non pb with compilation , then I register it like this :
name ProEConnectorDLL
startup dll
exec_file C:\Devel\ProEConnectorDLL\x64\Debug\ProEConnectorDLL.dll
text_dir C:\Devel\ProEConnectorDLL\text
delay_start TRUE
allow_stop TRUE
REVISION 18
end
then I launch it thanks to Tools/Auxiliary Application but when I start it I get the error message :
Please help!
Thank you
Did you check the trail file after the application run?.
Can you send what your userinitalize looks like.
Anika Kapoor
Hello!
Sorry if my question seems simple but where can I find the tail file?
Here is my userinitializee :
extern "C" int user_initialize()
ProError err = PRO_TK_NO_ERROR;
ProMode mode = PRO_MODE_UNUSED;
err = ProModeCurrentGet(&mode);
if(err == PRO_TK_NO_ERROR)
if(mode == PRO_TK_BAD_CONTEXT)
printf("ProModeCurrentGet error in user_initialize.\n");
return(0);
Thank you
I don't think trail file will help a lot... Generaly there is only a line with the same message than the error dialog...
First of all, you must check if the protk.dat paths are good in Help->System Informations->Auxiliary application Information.
If everything is OK, check if all dependancies of your dll is in the same directory.
BR,
Etienne
I checked the path from the protk.dat and they are good. I renamed the dat file protk_dll.dat, I guess it's not a problem.
I checked the dependencies and they are all in the same directory...
Do you have a small example project ofr example? I am using Visual Studio 2008 Express. Maybe it's something in the configuration of my project, if I could compare with a working .sln it could be very helpful
Thank you a lot!
Try with filename protk.dat instead of protk_dll.dat
nothing changed...
Try with a basic protk.dat:
startup dll
end
Check the path not in the protk.dat but in the auxilliary application information (after start fail).
My user_initialize function don't have the same prototype.
I have "extern "C" int user_initialize(int argc, char *argv[], char *version, char *build, wchar_t errbuf[80])".
Have you a "void user_terminate() {}" function ?
Here is what I have in my main.cpp :
Pro/TOOLKIT includes
#include "ProToolkit.h"
#include "ProCore.h"
#include <ProMenu.h>
#include "ProUtil.h"
ProEConnector includes
return(0);
extern "C" void user_terminate()
err = ProViewRefit (NULL, NULL);
if(err != PRO_TK_NO_ERROR)
printf("error %i.\n",err);
else
printf("Terminate.\n");
void main(int argc, char *argv[])
ProToolkitMain (argc, argv);
return;
Can you try removing void main function ?
I just did. but still I get the same failed message.
Hello Emilie,
I have testet that source code in Visual Studio 2005 with Wildfire 4.0 64-bit and it works perfect.
My settings:
Additional include path:
\ProTOOLKIT\Wildfire 4.0 M200\protoolkit\includes
\ProTOOLKIT\Wildfire 4.0 M200\protoolkit\protk_appls\includes
preprocessor:
PRO_MACHINE=36
PRO_OS=4
Lib dir:
\Wildfire 4.0 M200\protoolkit\x86e_win64\obj
lib:
protk_dllmd.lib
Greetings Lars
did you try with Visual studio 2008?
Is it possible that you send me your project, please? Maybe I did something wrong in the configuration.
Hello Emilie,
I think the Visual Studio 2008 Express version has no support for 64-bit programming?
Isn't it???
You want to get a 64-bit dll?
Have you installed an 64-bit ProE? Do you link your projekt to the 64-bit libs of protoolkit?
You can analyse your dll with the dependency walker (64-bit version).
Or send the dll to me.
Greetings Lars
I have installed the 64 bits version of ProE and I link with the 64 bits libs of protoolkit. and the weird thing is that I don't have a problem doing an 64bits exe... But as I wanted to have better perfo I decided to do a dll and even with a very simple project I can't get it to run..
Here is my dll.
Thank you for your help
I am really wondering why I have no problem generating and using an exe but it's not ok for a dll.
Do you have any clue on this?
What version of PTC product are you using : WF4, WF5, ProElement5, CREO1, CREO2 ?
For WF4, you must use Visual Studio 2005.
For WF5 and PE5, you must use Visual Studio 2008.
For CREO1 & 2, you must use Visual Studio 2010.
I have WF5 and I am using Visual Studio 2008 Express.
I will try with Visual Studio 2008 (not Express).
I finally managed!!
I am using Visual Studio 2008 with these settings :
-include files :
proeWildfire 5.0\protoolkit\includes
proeWildfire 5.0\prodevelop\includes
- libraries files :
proeWildfire 5.0\protoolkit\x86e_win64\obj
- Runtime Library : Multithread (/MT)
- Additional Dependencies :
protk_dll.lib
wsock32.lib
mpr.lib
psapi.lib
ws2_32.lib
netapi32.lib
And this protk.dat :
NAME | ProEConnectorDLL |
STARTUP | dll |
ALLOW_STOP | TRUE |
DELAY_START | FALSE |
EXEC_FILE | C:\Devel\ProEConnectorDLLPrj\x64\Release\ProEConnectorDLLPrj.dll |
TEXT_DIR | C:\Devel\ProEConnectorDLLPrj\Text |
END
Thank you for your help guys!
Emilie
for DLLs I use
Multithreaded-DLL (/MD)
with
protk_dllmd.lib
