I don't think that this would be possible from your machine.
You need a very good connection for remote debugging and also the ports need to be open.
A much easier solution is to push out a debug build (with .pdb) and check the traceback.log file. So you get an idea where it's crashing.
Br,
Eike
Thank you for responding on this.
Machine set up we can enable , if specification is known, with the help of our IT team.
Could you please elaborate more on how to go through pdb file? I guess it's binary file.
Thanks and Regards
Ketan
