Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
So simple I can't believe I didn't think of it: put it in a 1 x 1 table
Thanks to Catalin P, Ian C, Mike B, Stephen W, Kenneth S, and Bob F, all of whom suggested it within minutes of each other.
Lyle Beidler MGS Inc 178 Muddy Creek Church Rd Denver PA 17517 717-336-7528 Fax 717-336-0514 <">mailto:-> - <">http://www.mgsincorporated.com> This thread is inactive and closed by the PTC Community Management Team. If you would like to provide a reply and re-open this thread, please notify the moderator and reference the thread. You may also use "Start a topic" button to ask a new question. Please be sure to include what version of the PTC product you are using so another community member knowledgeable about your version may be able to assist.
