In Creo Element Pro (Wildfire 5) what is the J-Link equivalent of: Edit > Scale Model ?
Gerry Champoux
Williams International
Walled Lake, MI
As far as I know scaling cannot be done with the APIs.
It might be a good idea to try using a mapkey that is executed by BaseSession.RunMacro().
Andreas
__________________________________
Andreas Hellmann
MCAD Services Pro/E & Pro/E customization
Am Wartfeld 7
D-61169 Friedberg
phone: +49 151 21259910
I somewhat recall that in the pre-Wildfire days, we effectively scaled by changing the units.
Does anyone have some example J-Link code to do this?
And yes, it is my intent to create a J-Link app to recursively scale an assembly.
The recursion part is not difficult.
Gerry Champoux
Walled Lake, MI
In Reply to William Bowling:
It can’t be done directly but you can go through an assembly recursively and hit all the models with a change of units with appropriate options. I just finished a code that allows users to scale an assembly and it uses that approach. It’s done with toolkit so I don’t know about J-Link.
Gerry Champoux
Walled Lake, MI
