Setting element value
Sss4598
Hello all,
In pattern table the  instance values are set using ProElementIntegerSet or ProElement DoubleSet(). But sometimes I want to ignore some Instances in pattern table by adding @ symbol in idx column. How can I set value to @ so that the instance is ignored and read as comment?
Hi @Sss4598,
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Anurag
