Hi All,
When I register 3 different creo toolkit application all together, manubar and pushbutton name appear same for all, (same as per 1st registered application)
But when I register each application per each new session, manubar and pushbutton name its correct. Problem starts, when I register 2nd application in same session. Please let me know, how to resolve. Thanks in advance
Just a quick guess (since you did not explain how your message text files are named/referenced/located, and the message tokens within):
Looks like message files/tokens are equally named in the 3 different TOOLKIT applications and each asks Creo to look in a message file for the same message token M - and Creo caches/reused already read message tokens (over a Creo session).
Menu and message tokens should be unique (in a Creo session).
Hi @VA_3544793,
Please note that industry experts also review the replies and may eventually accept one of them as solution on your behalf.
Anurag
