How to simulate my mold see picture, I want certain heat toward mold formerly want maintaining 550 C° exactly how much time needs to temperature goes on 550 C° for whole mold? Mold material is SS 304
Thanks is that any video?
in muffle furnace.
I'm pretty sure Steve means how is the heat applied in your CREO model.
Is there a thin film heater applied at a surface or perhaps all external surfaces are convectively coupled to a high sink temperature (above 550C) as in your furnace? You may also have a condcuctive contact as well as you mold sits in the oven somehow. The model needs to have those heat sources identified as loads (conductive, convective and/or radiative).
You also need to set the start temp, most likely 20-23C.
