When I trying to unlock the makefile at customer end I got following error.
The requested binary file is not a Toolkit application.
Same makefile working perfectly on my System which have toolkit license. Please help me to solve this issue...
use this procedure:
MH
to be able to unlock ProToolkit application you need to have a license containing ProToolkit module.
MH
Hi Martin, thanks for the reply,
I need more clarification about toolkit licensing,
we have a single license for Protoolkit in my workstation, I am planning to develop toolkit applications in my workstations, finally I need to provide it to my team members, in that case Is it possible they can use my toolkit app without toolkit License? or every workstation should've toolkit license to use the toolkit app?
Do you have any Idea about this, please share...
use this procedure:
MH
Thank you very much Martin, Now its working
