The requested binary file is not a Toolkit application
PARTHIBAN_K
     When I trying to unlock the makefile at customer end I got following error.
     The requested binary file is not a Toolkit application.
Same makefile working perfectly on my System which have toolkit license. Please help me to solve this issue...
Parthiban Kannan
href="https://www.linkedin.com/in/parthiban-kannan/" target="_blank"
use this procedure:
  • make an application build (on your PC)
  • unlock the application (on your PC)
  • forward unlocked application to your colleagues (they do not need license containing ProToolkit module)
MH
Martin Hanák
to be able to unlock ProToolkit application you need to have a license containing ProToolkit module.
MH
Martin Hanák
Hi Martin, thanks for the reply,
     I need more clarification about toolkit licensing,
          we have a single license for Protoolkit in my workstation, I am planning to develop toolkit applications in my workstations, finally I need to provide it to my team members, in that case Is it possible they can  use my toolkit app without toolkit License? or every workstation should've toolkit license to use the toolkit app?
Do you have any Idea about this, please share...
Parthiban Kannan
use this procedure:
MH
Martin Hanák
Thank you very much Martin, Now its working
Parthiban Kannan
