Toolkit VC++ : How to Refresh the Session? Any help would be greatly appreciated.
Madhavi
Need to remove a drawing model from session.
I used ProWindowDelete/ ProWindowCurrentClose to close the Drawing model's window.
Then ProMdlErase to erase it from memory.
But I still get that drawing model in ProSessionMdlList.
If I use ProMdlEraseNotDisplayed to erase it from session then it gives me error. ( may be because  model was already erased)
Please let me know is there any way
to refresh the Session? or
forcefully remove the model from session?
Warm regards,
Madhavi
Give a try with below API sequence and update whether it is working or not:
ProMdlEraseAll
Thanks for reply.
But that does not work
Can i know version Nd datecode of Creo you have? I have not tried but I have feeling that previous APIs should solve purpose..
I came to know fantastic fact from toolkit documentation and might be helpful to you.
Once we use any API related to model erase, it does erase from memory once control is passed to Creo after execution of all toolkit command. If your work flow is not as per above statement, there might be memory issue.
HIH
Ketan
RPN
(To:Madhavi)
As far I know, you can’t change the current model in a synchronous session. Try to open a object from disk, this one you can change, save and erase if you are done,
