Does anybody know where I can find the VB API User Guide för Creo Parametric 2.0? I've managed to find one for Wildfire 4 and one for 5 but not Creo 2.0..
(Wildfire 5: http://www.ptc.com/WCMS/files/99870/en/vbug.pdf)
Thank you in advance!
BR
Heidi
Hello Heidi,
did you install the VB-API with Creo 2?
On my Desktop the vbug is under C:\PTC\Creo 2.0\Common Files\M070\vbapi
Nico
I haven't installed it myself but I'll pass this information along. Thank you Nico! ![]()
Hello again Nico,
If I want to install the VB API, do you know how I do it? I can't find it as an option when performing a reconfigure (customization) on my Creo2-installation. Do I have to install Creo from scratch? I already have the M080 so I can't do an upgrade..
BR,
Heidi
You have to install Creo from the iso-file you've downloaded. When you don't install it, there is no option in the standard ptc-setup. This should only be on the original iso.
Thank you again! I got it to work ![]()
seems I don't have rights to download the file, Can you send me a copy of it?
thanks.![]()
