VB API: replace part in assembly
ptc-5748551
hi pro
i'm trying to replace part A with part B in an assembly model, via VB API.
if any body know how to access this task, could you show me the code? i'll very appreciate you
6 REPLIES 6
Example Code: Replacing Instances
The sample code in the file pfcAssembliesExamples.vb located at <creo_vbapi_loadpoint>/vbapi_examples
contains a single static utility method. This method takes an assembly for an argument. It searches through
the assembly for all components that are instances of the model "bolt". It then replaces all such occurrences
with a different instance of bolt.
thanks a lot!
fact is
i have been play with 'vbapi_examples' for days...but i still can't make it works...
i think this example code is used to replace instance of specified part with its another instance.
so i created an assembly model includes a part with instances A and B,but it still doesn't work, throw an exception when app creating instance of new model.
and unfortunately, the model 'replaceinstance.sam' , use for vbapi_examples, is failed.it can't find mated component.
Hello!
About problem 'replaceinstance.sam'.
The way to resolve this: just create new instance at Family table in bolt.prt
The name of new instance must be: PHILLIPS7_8
It is difficult to find the problem, not seeing the code.
Can you share your code, where you call the method from the example? And the model of part with the family table.
woo...thank u ,the model "bolt.prt" can be used correctly "in replaceinstance.asm", but pattern is still incorrect, and i still can not figure it out ...
about the code , in my app, i just used the example code. just changed three arguments:Component Name, Old Instance, New Instance.
could u please send me a repaired model of "replaceinstance.asm"?
and as a fresh bird, may be i expressed my trouble by unclear words, that makes u hard to understand,
thank u for all.
I rebuild the .asm
http://yadi.sk/d/eaP0GXmFLEBY7
But I think, that this file will not help to resolve your problem.
Share the row of code, how you passing arguments:Component Name, Old Instance, New Instance.
thank you!
and sorry that replying so late, got some busy days.
i have downloaded the assembly,but it can not be retrieved...
may i have your e-mail? it is hard describe my code here...
