com.ptc.pfc.Implementation.pfcExceptions$XToolkitGeneralError
RGE
I am getting XToolkitGeneralError at times while starting ProEngineer in asynchronous mode through a J-Link program. When restarted the process, it is connecting to ProEngineer and working fine.
I am hoping the below change of code will show some useful result.
Are there any possible issues with this change?
nmahajan-3
2-Explorer
(To:RGE)
Did you find solution to this problem.? If yes can you please post the solution.
Nikhil I am also facing the same problem after changing java JDK and JRE. Earlier i was able to connect fine.
