Hi
I would like to speed up as much as possible the working directory setting.
Our final working directory is often a number that can vary from 1 to 9999
I would like to set up a procedure started with a mapkey (or, if it makes sense, any other way) asking this item code number and setting the working directory. The directory before this item code number can be the same (if the customer is the same) or can change (if the Customer is another one)
Let's make an example:
N:\ProE_Docs\Forgings\CustomerName1\10
N:\ProE_Docs\Forgings\CustomerName1\123
N:\ProE_Docs\Forgings\CustomerName2\9999
So, this path can change on the last two directories.
Is that possible to read a database where every item code number is assigned to a CustomerName, in order to know how to set the right path for that item?
In this way, when I call the macro, an input ask me the item number, read on the database to know the CustomerName assigned to that item code number and than the working directory can be set corectly.
I hope to have explained it in a clear way.
@mdenicola wrote:
Hi
I am almost sure that Creo OOTB functionality does not enable you to create requested macro.
I think that you can use AutoIt to develop small application that will fulfill your needs. You can launch such application (exe file) using Creo mapkey.
Hi Martin
thanks for your reply.
That's very interesting about this Autolt.
The problem is that I've no idea how to do that, lol
Maybe you could give me an help?
Thanks a lot
Marco
@mdenicola wrote:
Hi Martin
Thanks a lot
Marco
I can create AutoIt script for you, if you are not in a hurry. I guess I need one week to prepare the script.
Suggestion no.1 - workdir_database.txt (in this file you will be able to define working directories.
Customer=N:\ProE_Docs\Forgings\CustomerName1
10
123
Customer=N:\ProE_Docs\Forgings\CustomerName2
9999
Suggestion no.2 - AutoIt script functionality
Hi Martin
thanks a lot for your help.
I am not in a hurry at all.
What I was thinking to be useful and fast was that when the user have to set the working directory for that item , even without know where that directory is, write something like a mapkey called 'wd' + 'item number' :
wdxxxx
And that's all , the working directory has been set.
Is that possible such level of automation?
Marco
in select_working_dir_2020-06-26.zip you can find first version of setting working directory tool.
Please read select_working_dir_INFO.doc and ask questions if you need some explanation.
I tested the tool in CR4 M110.
Hi Martin
it works great!
Is it possible to change the path C:\PTC\autolt in order to have not a local but a path on the network where different users can access?
A good one could be:
N.\CADCAM_DOCS\ProE_Disegni\autolt
How can I learn how you did this program?
Marco
@mdenicola wrote:
Hi Martin
it works great!
Marco
you can place the tool in any directory. The only change you have to do is modification of mapkey definition.
You have to modify my definition
mapkey wd @SYSTEMstart C:\\PTC\\autoit\\select_working_dir.exe;
into your definition
mapkey wd @SYSTEMstart N:\\CADCAM_DOCS\\ProE_Disegni\\autolt\\select_working_dir.exe;
Notice doubled backslash characters in the path
To understand the tool, you have to:
Hi
one more help, if is possible:
with Creo 4.0 and higher version it works.
But I also use Creo Elements Pro 5.0. I tried but it's not working.
Is possible to make a version working for this old release?
Marco
Hi RPN
that's nice! Thanks.
Is that possible a faster way :
I type wd+id item number , for example:
wd1500
and the working directory is set to N:\\........\..........\.......\CustomerName\1500\
I mean the script can read a database or a text file how Martin has shown and know which CustomerName to set depending on the item number
Is that possible?
Sure, I work frequently with SQLite, text as well, or you parse on start and use dynamic arrays. It’s written in Tcl, I would say 200 lines of code for the GUI, it is a „hypertext“ text widget, to allow scrolling, 3 commands for creo, connect, message and change dir. And fur sure a“dirty hack“ just to archive the Target.
Mapkeys are not used, just „ps_cd <TargetDir>“. This not that complicated.
„Hunger comes with eating„ 😅 That’s what I believe in your case, e.g. clean Creo Session, Save modified in current session, load from folder, config customer env, to name a few.
Hi
Unfortunately to me this sounds too complicate . If you would like to develop this solution I would be very grateful.
Thank You
Marco
@mdenicola wrote:
Hi
Marco
I can slightly modify tool version released on 26-Jun-2020 to enable you to use the tool with Creo Elements Pro 5.0, too. Please wait 🙂
@MartinHanak wrote:
@mdenicola wrote:
Hi
Marco
in select_working_dir_2020-06-29.zip you can find modified version.
Please read select_working_dir_config.txt__INFO.txt file.
The tool can be "installed" twice ... you can call first instance from Creo 4.0 and second one from Creo Elements/Pro 5.0.
Hi Martin
The Creo Elements 5.0 version is not working.
It reads the select_working_dir_list.txt , I choose the customer name, than the item number, but after that
I get the error as shown in the picture.
The Creo 4 version it works.
I made two separate directories where the only difference is the file 'select_working_dir_config.txt' modified for the two versions.
Another thing:
In the select_working_dir_INFO.doc
I dont understand what you mean with:
line no.2 ... keyboard shortcut for opening Select Working Directory dialog box
Thanks a lot for your help
Marco
@mdenicola wrote:
Hi Martin
Another thing:
Marco
the problem may be caused by using the Italian version of Creo Elements/Pro 5.0.
I will send you additional information in next Reply.
@MartinHanak wrote:
@mdenicola wrote:
Hi Martin
Another thing:
Marco
I realized that I forgot to update select_working_dir_INFO.doc document.
Please read new select_working_dir_INFO_2020-06-29.doc document.
Hi
so, for WF5 the third line (the shortcut) of the select_working_directory.txt should be 'wl' (see attached image)
But I noticed that, while in Creo4 after pressing ALT+f+m+w , the dialog window open automatically, on WF5, after ALT+f+l the dialog window is not open but is like in the picture attached. It opens only after pressing ENTER.
Marco
@mdenicola wrote:
Hi
Marco
Picture is missing.
@mdenicola wrote:
sorry.. here it is
Maybe final question. Does the tool work in Italian version of Creo Elements/Pro 5.0 ?
no, it's not working.
Should I try to set WF5 in english language?
yes, please do it. I'll try Italian version.
I tested the tool with Creo Elements/Pro 5.0 M280 (ITALIAN).
The tool does not work because there are two commands using underlined character l (in File menu) - see picture.
Solution ... put following 3 lines into select_working_dir_config.txt file.
(attivo)
Creo Elements/Pro
fl{ENTER}
Hi Martin
now it works!
Amazing work, thank so much!
Marco
