anonymous wrote:
You have insufficient disk space for retrieval files to be recorded at the location specified in the configuration option : last_session_directory_path To set a different location for the retrieval files, click close, or make space available and then click Retry.
John,
I solved this issue on my PC. I just turned off this option in the config file. (last_session_retrieval no).Problem solved.
Paul.
Stuart,
I have never met this message. I guess it is caused by improper permissions somewhere in your user profile.
Martin
