How do i get a license.conf file
Mixers
How do i get a license.conf file?
All i can manage to get is lm text files.
FriedhelmK
(To:Mixers)
Hello again,
I think you should try there:
https://community.ptc.com/t5/System-Administration/bd-p/installation_licensing
Good luck
(Please write info in your Signature) Sysinfo: I use Creo Elements Direct /Drafting, /Modeling and /Modeling Express 8.0 ( formerly CoCreate- SolidDesigner and Drafting or ME10 )
6 REPLIES 6
FriedhelmK
(To:Mixers)
Hello
The licence.conf is a text file.
Change in the file Explorer  licence.txt  with rename in licence.conf  and ignore the warning.
Best regards Friedhelm
What do you mean by "lm" in "lm text files"?
http://kotom.eng.free.fr
Mixers
(To:Kotom-Eng)
I use Creo with a license server. This license server reads license.conf as the one with the license info. What i get from PTC are LM_xxxxx text files in the mail with information in it.. Renaming the files will not solve this as the content of the license.conf i need is very different than the information in the LM_xxxx files i get in the mail from PTC.
FriedhelmK
(To:Mixers)
May I ask which "Creo" cad program you are using?
If it is Creo x or another Creo Parametric related, then you are here in the wrong forum.
Here you are at Community Creo Elements Direct in the Modeling subsection.
Have a nice day
Mixers
(To:FriedhelmK)
Creo Design Essentials
FriedhelmK
(To:Mixers)
Hello again,
Good luck
