3-Newcomer
Mar 14, 2023 12:36 PM UTC
Connection path through CompactLogix in Dual-IP Mode
Trying to connect to an L30ER through an L310ER in Dual IP Mode. KEPServerEX Version is 6.10
As close as I can tell, the ID should be:
<10.10.10.1>,1,[4,192.168.1.2,1],0
However, I get an Invalid Device ID
I can connect through Ignition's OPC server with a connection path of. 4,192.168.1.2,1,0, but I'm not sure how that translates to KEPServer's ID.
aservetasAnswer
Mar 14, 2023 1:29 PM UTC
This is not possible within the driver at this time. Please refer to this article where that functionality is mentioned under the "Limitations" section.
https://www.ptc.com/en/support/article/cs299190
Best regards,
Andy Servetas
Principal Technical Support Engineer | Kepware Technologies
aservetas15-MoonstoneAnswer
Best regards,
Andy Servetas
3-Newcomer
Mar 14, 2023 2:41 PM UTC
Thanks, Andy. Do you happen to know if there's anything on the roadmap for this?
Mar 14, 2023 4:55 PM UTC
I have not heard of it being added to the product roadmap yet.
-Andy
