Community email notifications are disrupted. While we are working to resolve, please check on your favorite boards regularly to keep up with your conversations and new topics.
I tried to export the complex tags (advanced tags) created in one instance to other using Export/Import CSV it is not taking the mapped tags within them. How can i get it done with the mapped tags along with complex tag.
Greetings,
The Advanced Tags Plug-In supports the import and export of tag data in a Comma Separated Variable (CSV) file. When using CSV import and export, tags are created quickly in the desired application. CSV functions are only available when an Advanced Tag Group is selected.
Creating a Template
The easiest way to create an import CSV file is to create a template. For more information, refer to the instructions below.
To start, create an Advanced Tag Group. Then, define an Advanced Tag of each type to be used in the project.
Next, export the tag group as a CSV file.
Use this template in a spreadsheet application that supports CSV files, and then modify the file as desired.
Note: Users can save the CSV file to disk, and then re-import it into the server beneath the same tag group or a new tag group.
Note: Microsoft Excel is an excellent tool for editing large groups of tags outside the server. Once a template CSV file has been exported, it can be loaded directly into Excel for editing. A CSV file load in Excel would appear as shown below.
Once the tag list has been edited, it can be re-imported into the server by clicking File | Import CSV.
Note: This option is only available when an Advanced Tag Group is selected.
Mohit
Greetings,
Creating a Template
Mohit
