We are working to address an issue with subscription email notifications. In the meantime, be sure to check your favorite boards for new topics.
We have a Wago 750-362 Fieldbus Coupler Modbus TCP device from an outside vendor that I would like to collect data from. We have the Manufacturing Suite and I see the Wago Ethernet and Modbus TCP drivers. It doesn't appear that the Wago driver supports this model, but I'm not familiar enough with protocols to determine if I can use the Modbus TCP driver. Is the Modbus driver an option, or would I have to reach out to the vendor to see if they'd replace the device with an ethernet model? I am anticipating that they will be resistant to the idea.
Thank you.
Looking at the Wago document in the following link it appears as though the device only support Modbus TCP connections.
Fieldbus Coupler Modbus TCP (750-362) | WAGO USA
I would attempt to make the connection using the Kepware Modbus TCP/Ethernet driver and reach out to the Kepware through a support tick if additional assistance is needed. Here is a link to the login page where a ticket can be opened:
*Chris
*Chris
