Cycle Time Logging
Has any configured KEPServerEX to be able to run timers between a start and end trigger tags?
I want to be able to setup Operation Cycle Time Logging from plcs tags and be able to calculate the time that it takes for the operation.
Example: Timer between hit of a start button and final test saying that the test passed without having to create a timer in the plc itself to monitor this operation
Thank you
