Kepware to IEC 61850 write isuue.
Devam03
7-Bedrock
Hello team,
We are currently facing an issue with IEC 61850 device connectivity using Kepware v 6.15. We have connected an IEC Relay to Kepware with the IEC Driver and successfully browsed data from the Relay to Kepware. However, we are encountering a problem when attempting to write any bit from the Kepware Quick Client to the Relay. The commands are not being executed as expected.
To verify our setup, we have tested the same commands using IED Scout tool, Zenon SCADA, and IEC Explorer tool, and they were executed successfully in these environments. This suggests that the issue may be specific to our Kepware configuration.
For your reference, I have attached the ARU Backup file. We would greatly appreciate your assistance in diagnosing and resolving this issue
cmorehead
(To:Devam03)
@Devam03
I recommend opening a support ticket with the Kepware team as it appears some advanced troubleshooting will be needed. Here is a link to the login page where a ticket can be opened:
Log In | My Kepware
*Chris.
