kepware online license failing, offline works
JO_9930585
We have 2 kepware servers that needed online licensing. I was able to do online licensing for one of the servers but the other one failed with the error shown in the image below. I then did the offline licensing with success on this server, however, I need it to be online. I verified the server has internet and the credentials are correct. Can anyone help as to why one of our servers is rejecting the online setup?
ntripathi
(To:JO_9930585)
Greeting @JO_9930585
Please take a look at the following article as it may help resolve your issue:
https://www.ptc.com/en/support/article/CS332986
If you are prompted to log in to view the complete article, you can use your MyKepware login credentials.
Did you not read my post... "I verified the server has internet and the credentials are correct."
ntripathi
(To:JO_9930585)
Hi @JO_9930585
We found that you already logged a ticket for the same issue. We'll check it remotely to find the exact root cause.
