KepServerEX for communicating between two OPC UA Clients?
SOLVED
Highlighted
Participant
We have two OPC UA Clients (PC) and want to communicate between them using KepServerEx.
There i no PLC involved!!!
Is this possible?
if it is, which driver should I use?
The clients are Pi System and a customer specific program.
Tags (2)
1 ACCEPTED SOLUTION
Highlighted
Re: KepServerEX for communicating between two OPC UA Clients?
Greetings, you will want to use the Memory driver. It can be configured to persists values on server shutdown but more importantly because it is memory based and does not use a PLC all communications is processed via local memory cache.
2 REPLIES 2
Highlighted
Highlighted
Worked like a charm!
I have succeeded using the ODBC Client driver and MS SQL Express server (which was what the Swedish distributor recommended...), but this is much simpler!
Thank you very much!
// Anders
