Community Tip - Visit the PTCooler (the community lounge) to get to know your fellow community members and check out some of Dale's Friday Humor posts!
X
I need to stamp the current date on the drawings printed to the Océ Plotter TDS700.
Pro/Engineer printing procedure is configured to generate a plt file and the to call LPR program to do the actual printing. The plotter manual suggest to the command STAMP as an option of the /Job Ticket/ sent to the plotter. But I cannot understand what they mean... The plt generated is an HPGL file with no mention of anything that can be considered a /Job Ticket.
/I tried to insert some command I read in the manual before the .plt file generated by Pro/ENGINEER, just as I did for driving the machine attached to the plotter that folds the sheets, but it doesn't work.
Does anyone have some suggestion?
I understand this could be quite OT, but I hope that some of you may help me anyway.
La presente comunicazione, con le informazioni in essa contenute e ogni documento o file allegato, e' strettamente riservata e soggetta alle garanzie che legano i rapporti tra le parti interessate. E' rivolta unicamente alle persone cui e' indirizzata ed alle altre da queste autorizzate a riceverla. Se non siete i destinatari Vi informiamo che qualsiasi azione, copia, comunicazione, divulgazione o simili basate sul contenuto di tali informazioni e' vietata ai sensi della legge (art. 616 C.P., D.Lgs n. 196/2003 Codice in materia di protezione dei dati personali). Se avete ricevuto questa comunicazione per errore, vi preghiamo di darne immediata notizia al mittente a mezzo telefono, fax o e-mail e di distruggere il messaggio originale e ogni file allegato senza farne copia o riprodurne in alcun modo il contenuto. Grazie.
This e-mail and its attachments are intended for the addressee(s) only and are confidential and/or may contain legally privileged information. If you have received this message by mistake or are not one of the addressees above, you may take no action based on it, and you may not copy or show it to anyone; please reply to this e-mail and point out the error which has occurred. Thank you.
Prima di stampare questa comunicazione consideratene, per favore, l'impatto ambientale Please consider the environment before printing this email
