Adjusting number of decimal places displayed in template tables
jfrance
2-Explorer
All,
I have a quick query for you all, regarding the number of decimal places displayed in a table in a drawing template. A little background: we utilize UDFs and a drawing template to automatically generate a point cloud fromour CAD models,which is then utilized by manufacturing to determine the angle and trajectoryfor automated grinders. The default number of decimal places displayed in these tables is insufficient to provide accurate enough data points for the grinders, and as a result, engineers are currently having to reformat them manually to display additional decimal places.
I would like to update these templates to automatically display the desired number of decimal places in the tables. If someone could help me locate the parameter or .DTL file that controls this, I would be most appreciative.
Thanks!
Jason France
Design Engineer
Benchmade Knife Co.
3 REPLIES 3
Jason,
Just add [.X] behind the dimension in the table.
Where X is the number of decimal places you want to show. .2 = two decimal places .4 = 4 decimal places, etc...
BTW, I own several Benchmades, great knives!
-marc
Hi
I'm familiar with the parameter model_name, which we use in drawings
using the syntax &model_name
Can this parameter be accessed inside a part relation.
What is the syntax to use it?
Mark
Fisher & Paykel design starts with you in mind, check out the people and passion behind every Fisher & Paykel product.
Just don't use the "&" in front when you are in the relations.
Hope this helps,
Michael Ohlrich, Design Engineer
Benchmade Knife Company
mohlrich@benchmade.com<">mailto:mohlrich@benchmade.com>
(503) 655-6004 x122
[cid:image002.jpg@01CCA85F.C8E67E10]
www.benchmade.com<">http://www.benchmade.com>
CONFIDENTIALITY NOTICE: This e-mail communication and any attachments may contain confidential and privileged information for the use of the designated recipients. If you are not the intended recipient, (or authorized to receive for the recipient) you are hereby notified that you have received this communication in error and that any review, disclosure, dissemination, distribution or copying of it or its contents is prohibited. If you have received this communication in error, please destroy all copies of this communication and any attachments and contact the sender by reply e-mail or telephone (503) 655-6004).
