Anybody out there linking CAD to WT Parts - Clarification
mkorch
Thanks everyone for the replies. I need to clarify further.
We have existing Parts with Structure and existing CAD with a different
structure. Not pretty, but it's our starting point.
We want to as much as possible link the CAD to their respective Parts in
order to get the Representations. We DO NOT want the CAD to drive the Part
structure or change it. Curious if anyone has tried using any of the
relationship types beyond "Owner". And if so what your experiences with it
have been.
Thanks again!
Margi
Margi Korch
Information Technology
Mechanical and Manufacturing Engineering Solutions
Missile Systems
Raytheon Company
+1 520.545.6097 (office)
+1 520.203.4444 (cell)
6221 S Palo Verde Rd
Tucson, AZ 85706-5093 USA
www.raytheon.com
Raytheon Sustainability
This message contains information that may be confidential and privileged.
Unless you are the addressee (or authorized to receive mail for the
addressee), you should not use, copy or disclose to anyone this message or
any information contained in this message. If you have received this
message in error, please so advise the sender by reply e-mail and delete
this message. Thank you for your cooperation.
----- Forwarded by Margi S Korch/US/Raytheon on 07/01/2014 07:19 AM -----
3 REPLIES 3
Margi
We started in the same position as you mentioned. Past modeling practices allowed people to create assemblies that were then set to recursive in the drawing BOM and then filtered out. This practice called "Convenience Assemblies". This was allowed because the PDF of the final drawing was the master. Since then we have changed practice but we needed to address this practice when we started creating and maintaining product structure. For these assemblies, the engineer associated the model to the WT Part using a Contributing Content link and then imports the BOM from a CSV file created from the Creo repeat region. This captures the BOM as the master and provides a link to the corresponding assembly. We created the table to below to document the different scenarios that we typically see. If you have more interest, I can provide more information on this practice and others.
[cid:image001.png@01CF9522.F7626080]
Corey L. Jones
Design Engineering Systems Specialist
Principal Engineering Technology Development Group
ESC - Team QNA
SGT Inc.
Kennedy Space Center, FL 32899
NE CAD Green Effort - Digital First - e-documents, e-approvals, e-release, e-distribution
NOTICE . . . The information contained in this communication may be sensitive, proprietary, legally privileged and/or subject to U.S. export control laws, is intended only for the use of the recipient named above. You agree to comply strictly with all U.S. export laws and assume sole responsibility for obtaining licenses to export or re-export as may be required. If the reader of this message is not the intended recipient, you are hereby notified that any dissemination, distribution, or copying of this communication, or any of its contents, is strictly prohibited. If you have received this communication in error, please re-send this communication to the sender and delete the original message and any copy of it.
ocorten-2
(To:mkorch)
Hi Corey,
Isn't this easier accomplished by setting the Common Attribute "Gathering Part" for these "Convenience Assemblies" to Yes?
Assembly OC0003 in the example below:
The Single Level BOM filters out the Gathering assembly and puts all it underlying parts to the upper level (just like the recurse/filter trick in repeat regions)
Kind regards,
Olaf Corten
Olaf Corten | CAD/PLM Manager
Besi Netherlands B.V. | Ratio 6| 6921RW Duiven| The Netherlands
T: +31 26 3196215 | M: +31 644548554
- | www.besi.com
From: "Jones, Corey L. (KSC-ESC-643)[SGT - ESC]" <->
To: Margi S Korch <->, "-" <->
Date: 01-07-2014 17:53
Subject: [proecad] - RE: Anybody out there linking CAD to WT Parts - Clarification
Margi
We started in the same position as you mentioned. Past modeling practices allowed people to create assemblies that were then set to recursive in the drawing BOM and then filtered out. This practice called “Convenience Assemblies”. This was allowed because the PDF of the final drawing was the master. Since then we have changed practice but we needed to address this practice when we started creating and maintaining product structure. For these assemblies, the engineer associated the model to the WT Part using a Contributing Content link and then imports the BOM from a CSV file created from the Creo repeat region. This captures the BOM as the master and provides a link to the corresponding assembly. We created the table to below to document the different scenarios that we typically see. If you have more interest, I can provide more information on this practice and others.
Corey L. Jones
ESC - Team QNA
SGT Inc.
NE CAD Green Effort- Digital First - e-documents, e-approvals, e-release, e-distribution
Yes, it is. Unfortunately, this isn’t the only issue with our “heritage” models and drawings. Also, when we began this journey, we did not understand the full impact
of gathering parts.
Corey L. Jones
ESC - Team QNA
SGT Inc.
Tel - (321) 867-9104
E-mail - -<">mailto:->
cljones@sgt-inc.com<">mailto:cljones@sgt-inc.com>
Looking for ProE or Windchill information?
Checkout the user community NE CAD/CAE Resource share point site at: -
