Hello, All
When I use Cutline Milling to mill a hole, I use Type_Helical , however, I found that I can not set Helical Pitch for Helical milling.
Can anyone help me on this issue?
Have you tried adjusting STEP_OVER to a smaller value?
you are absolutely right, the pitch is controlled by STEP_OVER.
thanks for your help!
