Direct interface to export BOM to Excel
gcambiaghi
Good evening
In the Emx 12.0.0.0 options there should be the configuration menu of the BOM export in excel, to me it is not active, in the configuration folder the excel_export_configuration.cfg file is present, do you have an explanation for how to configure the BOM?
3 REPLIES 3
I hope @tschneyer can answer the question.
Martin Hanák
gcambiaghi
(To:MartinHanak)
Thanks Martin
Hello gcambiaghi,
The Direct Export to Excel interface is only avaiable with Expert Moldabse Extension 12.0.0.1
Kind Regards Thomas
https://www.youtube.com/user/buwsoft
Kind Regards
Thomas Schneyer
B&W Software GmbH
Welcome to B&W software GmbH We are the world's leading supplier of add-on applications for the 3D CAD system PTC Creo Parametric (previously Pro/Engineer) from PTC. Our goal is to provide users of this innovative system applications that make it possible to work faster and more efficiently with ...
