Local Mill
jcarvalho
Local Mill
Na versao nova do CREO 3.0 M20 não consigo executar (local mill) após uma operação de (Windows mill ou Volume mill), mas é uma operação normal no CREO Parametric .
Como resolver este problema?
Na versao M50 ja esta resolvido.
Manufacturing
""In the new version of CREO 3.0 M20 I can not run (local mill) after an operation (Windows Volume mill or mill), but it is a normal operation in CREO Parametric.
How to solve this problem?
In the M50 version is already solved?
2 REPLIES 2
BillChapman
(To:jcarvalho)
The volume milling sequence was redone in Creo 3.0.  I believe that the new volume sequence does not yet support local milling.  The workaround is to
Set “ENABLE_CLASSIC_NC_STEPS” to “YES”
This will allow you to use the new volume or the old volume sequence.  If you want to use local milling you will need to use the old volume sequence.
gkoch
(To:jcarvalho)
Hello Jose,
did it work with classic sequences?
Here is the related article from our database: CS191225 : Unable to create Local Milling sequence with error message "Tool path could not be created; Please check the setup" in Creo Parametric 3.0
Gunter
