Corrupted File Unable to Open
AP_10747112
2-Explorer
I am using Mathcad Prime Release 5.0 and Datecode5.0.0.0
I was using Mathcad Prime to perform a series of calculations. After attempting to edit the amount of decimal places I wanted to display, the application froze and then crashed. Before crashing, the file I was working in had saved, however when I attempt to reopen the saved file, the application prompts me with the message written below in the "Error Messages or Warnings" section. I has saved my original file once I created it, however I had not periodically saved while working. The file that did save, saved as a new file on my computer. I was roughly 5 pages into the file and would like to recover my work if at all possible. I am working on a very time sensitive project that will be greatly impacted if this file cannot be recovered.
Thank you in advance, Austin Picaso
The file type is not supported.
Log file is located at
C:\ProgramData\PTC\Mathcad
Prime\Logs\MathcadPrime_Exception_20230728_155458.log
Hi Austen,
Please upload the file.  Some people in the community may be able to reopen it.
Cheers
Terry
LucMeekes
(To:AP_10747112)
Upload the worksheet (.mcdx) file (not the .log file).
