The message you are trying to access is permanently deleted.
As a Mathcad User if you happen to receive an error message "An Unhandled exception occurred on the dispatcher thread. See “C:\ProgramData\PTC\MathcadPrime\Logs\MathcadPrime_Exception_###.log"
Than to address the problem, lets first understand the reason for this error followed by Resolution.
Root Cause of Error:
Resolution: There are two resolutions to address the problem
Resolution 1 -
1. Rename the file MathcadPrime.exe.Config to old_MathcadPrime.exe.Config in the default Mathcad Installation location "C:\Program Data\PTC\Mathcad Prime".
2. Rename the folder #PTC to old_PTC in the location " C:\Users\%username%\Appdata\Local"
3. Clear Temporary files on the Machine
If the above instructions fail to resolve the issue, uninstall the application, reboot the machine and reinstall Mathcad Prime
Resolution 2 -
i tried all of them but didn`t work. I only got this error when i try to enter a number after this " := " .
Can someone help me ?
What version of Mathcad Prime and Windows OS are you using?
did you solve the problem in the meantime?
Dear Collegue!
I have tried these Resolution but nothing worked!
I have the MathCAD 8 express free version and I can´t open the .mcdx file.
Till today there werent any Problems opening the file.
And I am speechless because its a very important file to me and I need it for University.
I would be very thankfull if somebody could help me!!!
If somebody could convert it to pdf it would be enough for me.
In kind regards!
The Problem is I can neither open it nor convert to pdf but need the calculations ://
Edit: Luc Meekes fixed it for you here.
Edit 2: ...And in this thread, too!
____________________________________
It seems like there's something wrong with the file since I can't open it.
File location : C:\ProgramData\PTC\Mathcad Prime\Logs\MathcadPrime_Exception_20220512_084232.log
Build Number : 2022.03.01.001
System Culture : en-US; Current UI Culture : en-US
Architecture: x64
Application version is: PTC Mathcad Prime 8.0.0.0
Current license type is: Commercial
Exception data:
File being opened: C:\Users\danewman\Downloads\Neuberechnungen.mcdx
System.FormatException: Incorrect serialization format ---> System.Xml.XmlException: Name cannot begin with the '1' character, hexadecimal value 0x31. Line 1, position 13627.
at System.Xml.XmlTextReaderImpl.Throw(Exception e)
at System.Xml.XmlTextReaderImpl.ParseQName(Boolean isQName, Int32 startOffset, Int32& colonPos)
at System.Xml.XmlTextReaderImpl.ParseElement()
at System.Xml.XmlTextReaderImpl.ParseElementContent()
at System.Xml.XmlLoader.LoadNode(Boolean skipOverWhitespace)
at System.Xml.XmlLoader.LoadDocSequence(XmlDocument parentDoc)
at System.Xml.XmlDocument.Load(XmlReader reader)
at System.Xml.XmlDocument.Load(Stream inStream)
at Ptc.Controls.Core.Serialization.McdxDeserializer.Deserialize(Stream stream)
--- End of inner exception stack trace ---
at Ptc.Controls.Core.Serialization.McdxDeserializer.ThrowIncorrectSerializationFormatException(Exception ex)
at Ptc.Controls.EngineeringDocument.DeserializeWorksheetSection(PackagePart part, IWorksheetSectionPersistentData sectionData, IRegionCollectionSerializer regionCollectionSerializer, String fullFilePath)
at Ptc.Controls.EngineeringDocument.DeserializeWorksheetAndHeaderFooter(Package package, String fullFilePath)
at Ptc.Controls.EngineeringDocument.Read(Package package, FileLoadResult& result, String fullFilePath, Boolean newFromDocument)
at Ptc.Controls.EngineeringDocument.OpenPackage(FileLoadResult& result, String fileName, Boolean newFromDocument)
at Ptc.Controls.EngineeringDocument.OpenFileAndUpdateCWDState(String fileName)
MathcadPrime started at:
08:42:26 05/12/2022
Hi, Are you solve the ":=" problem?
Hi, yes, I did! I use a German version of Mathcad and I switched the language of my laptop to German, and it worked. I know that sounds silly but apparently the languages should match. I hope that works for you as well.
Thanks for sharing your solution to this issue.
i cant solve the problem , then i using Turkish language on my computer, so ı will try english version both, but i cant switch language mathcad.
What version of the program are you using?
Prime 8
"How to launch Mathcad Prime in a specific language":
I have solved it!!!
After I changed pc language from Turkish to English, the problem was solved.
By the way, the Mathcad program language is also English.
