Community Tip - Did you get called away in the middle of writing a post? Don't worry you can find your unfinished post later in the Drafts section of your profile page.
X
I entered registration data to obtain a download link, received the link, and downloaded the installer. When I run the installer, it starts unpacking, but at the end of the unpacking process, the installer simply closes, and that's it.
I tried extracting the installer and looking for the files mentioned on forum, but the only executable file in the installer is setup.exe.
