I tried all of that and it did not work. Thank you for your help.
Hi @Trapezoid,
Can you verify and confirm if the issue persists even after changing the user login credentials
For e.g. try logging into the system with different credentials (administrator) and see if Mathcad Prime opens fine or gives the same error.
Vipul
Hello @Trapezoid,
Did you tried the suggestion provided in the last post?
Let me know the status at your end for further troubleshooting
Vipul
