Error "An Unhandled exception occurred on the dispatcher thread".
  • January 8, 2021
  • 11728 views
As a Mathcad User if you happen to receive an error message "An Unhandled exception occurred on the dispatcher thread. See “C:\ProgramData\PTC\MathcadPrime\Logs\MathcadPrime_Exception_###.log"
Than to address the problem, lets first understand the reason for this error followed by Resolution.
Root Cause of Error:
  1. MathcadPrime.exe.config may have been corrupted
  2. User.config is corrupted for the user trying to launch Mathcad Prime
Resolution: There are two resolutions to address the problem
Resolution 1 -
1.  Rename the file MathcadPrime.exe.Config to old_MathcadPrime.exe.Config in the default Mathcad Installation location "C:\Program Data\PTC\Mathcad Prime".
2.  Rename the folder #PTC to old_PTC in the location " C:\Users\%username%\Appdata\Local"
3. Clear Temporary files on the Machine
If the above instructions fail to resolve the issue, uninstall the application, reboot the machine and reinstall Mathcad Prime
Resolution 2 -
  1. Alternate workaround is to copy Mathcad Prime Folder from the location C:\ProgramData\PTC from a machine on which Mathcad Prime is up and running and paste it to the same location on the machine having issue.
  2. If the former resolution does not solve the issue, uninstall the add-on Microsoft .Net Framework, download and re-install the local language version
  3. Uninstall and re-install Mathcad Prime
i tried all of them but didn`t work. I only got this error when i try to enter a number after this " := " .
Can someone help me ?
What version of Mathcad Prime and Windows OS are you using?
