I assume you succeeded in installing the program: it runs when you start it.
Then you are now running Prime Express: there is a diagonal banner across the worksheet.
Go to the license menu (Press the circled M in the top left corner of the window, then select 'Options' from the list and go to the license tab)
Press the 'get license' button.
Select the type of license that you want (the 30-day trial...) and follow the instructions.
Sukces!
Are you not getting to this page?
check here: https://community.ptc.com/t5/Mathcad-Installation/Blank-Application-Selection/m-p/710372
Sukces!
