2D lines on a contour plot
ptc-4732704
In the MathCAD Prime 2.0, I was trying to add a 2D constraint graph line to a contour plot to indicate the constrained optimum. However, I have no idea on how to do that. Is there a way?
Thank you so much in advance!
May be this picture help you:
http://twt.mpei.ac.ru/ochkov/Mathcad_12/1_70_Plot_Pad.png
Superposition is another way in standard Mathcad; here's an example using CreateSpace ... I haven't got Prime 2.0, so I don't know whether the method will work on it.
Stuart,
Do you know why the y axis is inverted, i.e. the negatives are at the top and the positives are at the bottom?
Harvey Hensley wrote:
Stuart,
Yes. I was using the joint Australian/Transylvanian protocol (favoured by submariners). Try Twist 90, Tilt 90.
Stuart
Stuart,
Just catching up on some stuff. "Twist 90, Tilt 90". Is that the movie script direction for the actor who's just been shot?
H
