3D plots are empty in my newly installed Mathcad 15.
It does not even display in quick sheets.
Everything worked fine in Mathcad 14.
But I uninstalled that before checking.
Lasse
I solved the problem by changing from 32 bit colour to 16 bit colour. It made contous pop up but the lettersin menues inside and ouside Matcad now is blurred especially when ther is a fillcolour in the menus (light gray, light blu)
Right-click on the plot, then disable "Border":
P.S. What version of Windows OS and Mathcad 15 service release (F000, M005, M010) are you using?
Lars Bergdahl wrote:
...Everything worked fine in Mathcad 14.
But I uninstalled that before checking...
On one computer programs Mathcad 14 and Mathcad 15 cannot be simultaneously installed. Therefore at installation Mathcad 15, the setup deletes Mathcad 14.
How do I disable Border? It's inactive in my menue.
Windows 2007 Home Premium.
Release M010
How about that:
P.S. Also, try to disable "Aero" mode in Windows 7.
