Moving to Mathcad Prime 9 from V15, and noticed there are no rules or guidelines to align the different regions of the document.
Any suggestions/tips/tricks to align the regions other by eyeballing them?
Unfortunately this is one of the features which still are missing in Prime.
So you are on your own and can only use the grid lines as a guide when aligning the regions manually purely on eye.
As the cursor jumps to the grid lines you may use the fine grid size for better precision.
