Error "Exception has been thrown by the target of an invocation" in MathCad Prime 10
  • January 30, 2025
  • 844 views
I'm doing a EDO resolution, and at the end of the resolution block I get error "Exception has been thrown by the target of an invocation"". If someone understood how to solve or the reason for this error. Thanks
Best answer by LucMeekes
You should attach the worksheet, not only a picture, and state which version of Prime you are using.
All i can see in your picture is that:
- alpha and beta are undefined.
- There appears to be a multiplication symbol (*) missing:
    - in the first differential equation, between C(s) and (mu.m...)
    - in the other two DE's between D and (1+R.1), which makes D seem like a function.
For alpha=beta=1, I get:
LucMeekes23-Emerald IVAnswer
Thanks a lot, the error was due to 3 missing multiplication symbol. Thank you very much
