Animate a set of data(x and y values only)
dgarzase
I have a set of data that has appx 27,000 lines. The data is in excel. I can plot the data from tables but is it possible to animate the data starting from the beginning of the data? The data mimics a hysteresis graph and plots nicely. I would like to animate the data.
RichardJ
(To:dgarzase)
See the attached worksheet.
9 REPLIES 9
RichardJ
(To:dgarzase)
You can animate a graph in Mathcad 15, but not in Mathcad Prime.
Richard,
Say I have a set of data as such,
20
30.15
40
5-0.15
60
71
80
9-1
100
111.5
120
13-1.5
140
151.7
160
17-1.7
180
191.71
200
21-1.71
220
232.8
240
25-2.8
260
272.95
280
29-2.95
300
313.2
320
33-3.2
340
354
360
37-4
380
396
400
41-6
420
438
440
45-8
460
479.2
480
49-9.2
500
5110
How do I take this data and animate?
RichardJ
(To:dgarzase)
Which version of Mathcad do you have?
What do you want to animate? Do you want to show one point on a graph that starts at 2, 0, then moves to 3, 0.15, etc?
I have 14 in my personal laptop and 15 at work computer.
You are correct, start 2,0 then 3,0.15 and so on.
Final graph below.
I also have a larger file with a-lot more data but if I can do this one, the larger one should not be a problem.
RichardJ
(To:dgarzase)
Thank you Richard, this is exactly what I was looking for. I will be in contact if the larger file does not work.
Richard,
What if you have 10,000 or more rows of data? How do you animate?
RichardJ
(To:dgarzase)
You need a high frame rate.
Got it, thank you.
