Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
Appendprn wasn't working for me, the output file was limited to 28 characters, continuing on the next line. I need a continuous string of +200 characters. I tried using Appendfile, but it won't work, any tips you can offer are appreciated.
