Trace funcition and window not working
I am using windows Vista first of all...I don't know if that has anything to do with this problem or not. But, there are several things that don't seem to be working right in my version of MathCad 14. One thing right away was when I placed and Excel 2007 component with column labels in my worksheet and redefined the properties of the labels to maker sure they were defined in my work sheet ...they were never usable. Then the execution of any loop programs did seem to either work at all or would have no output. Then I tried the debugger toggle and trace window. The trace window opens but nothing is ever in that window. I even opened a blank worksheet and copied the the trace example in the help quick sheet section. I ran the = (execution) command with debugger ...nothing. So something has got to be wrong with math cad program..right?
HEELP!....
HEELP!....
